flashlightguy84
- Joined
- Apr 7, 2018
- Messages
- 2
Hi all!I have a dead Nitecore MH20 that I'm looking to disassemble. I've already removed the lens, bezel, reflector, and desoldered the LED. I'm now stuck, however. Since the LED tested good, I'd like to remove the driver circuitry to check for loose connections or bad solder joints that I've seen reported elsewhere. I tried to poke the driver board out with a punch but was unsuccessful, and I didn't want to apply too much force for fear of damaging the board. Does anyone have any experience disassembling an MH20? Do I need to use heat to break up any adhesive? Do I need to remove the switch first? Any help will be appreciated.Thanks and have a great day!-Jeremy
