With all of the discussion on the Eveready Dolphin lights in the recent thread on the 1AA Energizer Weatheready "Pico" LED, I was very pleasantly surprised to find a 6 Volt Mark 1 Dolphin for $3 at Goodwill!
A lot of people had these back in the late 60's and 70's, often keeping them in their kitchen, garage or basement for use around the house, in their vehicles for emergencies or to take fishing, camping or boating. In the pre-Maglite era, these were a good choice for a rugged, dependable light – much better than the typical 2D plastic flashlights of the day that usually needed to be slapped around to get them to light up.
This one was in real good shape for a 50 year old light, nothing corroded or beat up too bad an the lens only a few small scratches. Since I have moved on from incandescent bulbs, I immediately replaced the bulb with a Rayovac LED drop-in (same or very similar drop-in is offered by Dorcy) – only about 40 lumens but has very good throw with a tight hot spot for distance combined with a large spill beam just bright enough to keep from bumping into things up close and the drop-in will run near forever on a 6 Volt battery. Speaking of which, if you don't want to mess with the 6 Volt batteries, 4D to 6 Volt adapters are available from Dorcy, providing dual fuel capability and if you have AA to D cell adapters you can also use AA's!
The old Mark 1 is of much sturdier build quality than the typical plastic 6V lights of today.....the plastic case is thick and durable, the screw on reflector/lens assembly appears to be decently water resistant and the switch has a nice solid CLICK. The wires that connect the head of the light to the switch do seem a bit vulnerable, so you may need to be careful with them when changing batteries and bulbs.
If you come across a Mark 1 at Goodwill or a yard sale in working order it still can provide many more years of faithful service with a LED drop-in and maybe a 4D to 6 Volt adapter at a modest cost.
