Hi guys, haven't posted in a while. I noticed my ARC4+ doing something weird when used for extended periods of time. First, I have primary set at level 4. Second, I usually use my ARC4+ for 1-2 minutes at a time. But lately I've been in situations where I've needed my ARC4+ for about 8-10 minutes. What happens in this situation is the light will sort of flicker 1 or 2 times, then it won't let me access the boost function. It doesn't step down to the next lower level, it just flickers a bit on level 4 and refuses to go to boost. When I unscrew, then tighten the tailcap, the light goes through RFS without a hitch, so the battery is fine. Could it be the thermal sensor protecting the LED? It seems that it would take more than 8-10 minutes of runtime on level 4 to trip the thermal sensor. Does anyone have any input?
