Hi , I've hit on a cheap trick for 'correcting' unpleasant LED color casts- thought I might share.
1- You cannot perfectly correct a cast
2- Any correction through filtration automatically results in a loss of light, measued any way you like- Lumens, Lux or CPS.you will loose photons in the process.
3- Color Correction filters (CC) work but are awkward to use in flashlights
4- Drum roll please....Introducing...The ubiquitous SHARPIE Fine Point Permanent marker ! Before you write this off as crazy. It's cheap, removable ( Denatured alcohol, or after-shave) and because it's on the LED emitter's lens, is completely unobstrusive. Now the fun part...WHICH Sharpie colors work?
5-For nasty ol Nichia LED's I use the ORANGE sharpie for what I describe as a 'Faded Starawberry' Hue. Before you scream..remember what I said about light loss? It happens that you will lose about 20% of the light BUT it will be twice as easy for you to distinguish objects in the dark in this wavelength. Sounds crazy but it isn't...in practice. This is because our eyes (and indeed most lenses) have trouble focusing light in the Blue end ot the spectrum (ask me for more details on this)..and yet, even with less actual light, our eyes can focus more easily in the Red end of the spectrum. This Strawberry hue is between Orange and Red- a nice sweet spot.I've done this trick to my SL TT2L (Cyanish Nicia's) and it works perfectly! I've not had the priviledge of owning an ARC Luxeon first run or other greenish/yellowish Bin lights- so I can't recommend a Sharpie color but I would guess that either the Red or Magenta Sharpies would work. Remember, you are replacing a nasty cast with a less nasty & more useful one.For a more accurate shift, CC filters or professional tinting would be best. Theoretically, a light Magenta tint woould work- CC5M or CC10M.In practice, LED color is not the same as incandescent- for which CC filters were designed. Trial & error tweaking is indicated here. /ubbthreads/images/graemlins/banghead.gif
