Re: life of 5W, 1W luxeons compared to regular LED
From Lumileds' own data sheets:
1W star
emphasis added
[ QUOTE ]
Average Lumen Maintenance Characteristics
Lifetime for solid-state lighting devices (LEDs) is typically defined in terms of
lumen maintenance—the percentage of initial light output remaining after a
specified period of time. Lumileds projects that Luxeon products will deliver on
average 70% lumen maintenance at 50,000 hours of operation. This
performance is based on independent test data, Lumileds historical data from
tests run on similar material systems, and internal Luxeon reliability testing.
This projection is based on constant current 350 mA operation with junction
temperature maintained at or below 90°C. Observation of design limits
included in this data sheet is required in order to achieve this projected lumen
maintenance.
[/ QUOTE ]
3W star
emphasis added
[ QUOTE ]
specified period of time. Lumileds projects that Luxeon III products will deliver,
on average, 70% lumen maintenance at 50,000 hours of operation at a 700 mA
forward current or 50% lumen maintenance at 20,000 hours of operation at a
1000 mA forward current. This performance is based on independent test data,
Lumileds historical data from tests run on similar material systems, and internal
Luxeon reliability testing. This projection is based on constant current operation
with junction temperature maintained at or below 90°C. Observation of design
limits included in this data sheet is required in order to achieve this projected
lumen maintenance.
[/ QUOTE ]
5W portable
emphasis added
Assuming 500 hours operation under given conditions...
<font class="small">Code:</font><hr /><pre>
typ °C If lumen maintenance
35° C 700 mA 90%
75° C 700 mA 75%
85° C 600 mA 65%
</pre><hr />
[ QUOTE ]
Note:
Luxeon V Portable is designed primarily for portable lighting and other applications requiring operating lifetimes of 500 hours and less. While the device will operate past 500 hours, its lumen maintenance cannot yet be characterized. Longer life versions of white Luxeon V will become available in the future.
Average lumen maintenance is dependant on heat-sink temperature. A recoverable light output loss may occur during the first 500 hours of operation.
[/ QUOTE ]
