Powerful throwy compact tactical with Quark123-like form factor?
Sanne de Vries
Dear all,
Which flashlights would you advice me to consider based on the following checklist? Your thoughts and guidance are much appreciated!
Sanne
==================Flashlight Recommendation Checklist================
This will be mail-order or Online. I am located in Germany.
2) Budget: An easy question, but you may change your mind after answering the rest! :)
Up to $200, but less is preferable. I will pay for quality, but value for money is important. I will not pay for a fancy brand logo or to impress friends.
3) Format:
I want a flashlight (hand held/self contained).
4) Size:
TINY - Every day carry (2-4 inches).
Size and sleek form factor rather as 4Seven Quark 123 than eg. Zebralight SC600-III.
5) Emitter/Light source:
LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
I want to buy a light that is ready to go out of the box.
I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
Or a light with an integrated rechargeable battery pack.
I want a light that has a recharging adapter (your typical "wall wart")
Or a light that can be recharged via USB.
8) How much genuine out the front (OTF) light do you want/need?
I want to illuminate an entire field, the neighbor's front yard several houses down (300-700 lumens).
I want search and rescue type illumination (800+ lumen) in burst/turbo mode.
I also want a true moonlight output mode (<1 lumen)
Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
Occasionally: Less than 1 meter (reading, other close work) in moonlight mode
Typically: 5-20 meters (check out a noise in the backyard)
Occasionally: 50-150 meters (I live in a very rural area/farm with wide open spaces)
90-120 minutes on high non-turbo/burst mode (Runtime is moderately important, but not critical)
Very Important (Camping, Backpacking, Car Glove-box).
I liked the tail mounted switch on my 4Sevens Quark 123 (found on the majority of today's high end lights).
I might also like a body mounted switch (near the head, like on a Maglite).
I want a momentary switch for ~18Hz strobe flash use
I don't know what forward (Helpful for momentary activation and signaling) and reverse clicky (For use with multi-mode/level lights) mean.
I do not need a BIG switch (I won't be using gloves or have very large hands or coordination issues).
I don't want a twisty switch (Tighten the head/tailcap to activate, and the light will stay on until the head/tailcap is loosened).
I don't need a remote switch (usually found on high-end bicycle headlights)
I want multiple light levels. (Some lights have 5-16 light levels.)
I would like a programmable light.
I want a strobe mode of around 18Hz. (Oscillating pattern to confuse/blind aka "Police Mode")
14) Material/Finish/Coating
I don't know. I highly value robustness and durability, but do not mind proneness to superficial dents or scratching on coating. Light-weight soons wins over price. Durability soon wins over light-weight. The surface should be grippy (through coating or profile), preferably dark and matte/non-reflective.
15) Water resistance
At least IPX4 (Splash resistant)
Preferably IPX7 (Waterproof to 1 meter/30min)
16) Storage conditions
Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
17) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned?
Neutral white light (for discerning between green/brown foliage colour shades) would be a pro.
Optional Red filter would be a pro (for preserving night vision).
No/removable Pocket/belt clip would be a pro.
Twisted eight shape finger grip (as here with the 4Sevens Quark 123: http://i243.photobucket.com/albums/ff97/selfbuilt/Quark-3.jpg) would be a pro.
Sanne de Vries
Hm. I must be doing something not quite right. Is it to do with the way I asked, did I compose incompatible requirements, something else altogether?
Bullzeyebill
CA
Please see the Administrative Announcements forum. Info for new members is addressed there.
Bill
