Hold down the right "TEST" button until it says TEST. That will do a charge/discharge/charge cycle.
When the TEST light is up a long press on the left button will enter REFRESH mode which is a discharge/charge cycle.
The TEST mode will give you true capacuty, the REFRESH mode does what it says.
P
Test and discharge are different functions. Just press and hold the left button for a discharge/charge cycle. The LED will turn blue, although for NiMH it will be red charging for a few minutes, then turns blue.
