I've got the white Ikea Ladda AAA NIMH batteries. Pack of four. Bought some five years ago.
One pair has lived as a swap in to my single AAA MP3 player, so each battery gets used in my player for the day, then gets swapped with a fresh battery the next day for a solid 10 hours of playing time.
The other pair has lived in my remote control and has been charged at most 10 times in the past 5 years.
I've used the Ladda USB charger the entire time. My LaCrosse charger died long ago, and the Ladda charger has proven adequate, although in this case, I do wish for some of the info from the LaCrosse.
Recently the MP3 AAA's have been lacking in playing time, so being many years into it's role, a fitting retirement into the remote control was in order with those batteries being called up to front line duty seemed in order.
Surprisingly the remote batteries has the same 'capacity' as the batteries they replaced even though they've seen 1/20th the number of cycles. Both sets might be able power on for a couple of hours, but if I fast forward a track, which may have an increased current requirement, causes a voltage drop and power off the player. This can happen within a half hour, or after a couple of hours. This may depend on each individual battery, or possibly the imperfect charger I'm using, although I've read that each compartment has a seperate charging circuit.
Interestingly enough, both sets from the same pack seem perfectly fine in all other devices, especially my high demand 2xaaa headlamp, and surprisingly, I think that my one pair of 1st gen chrome/green Laddas have enough capacity to last me an entire day and will be pressed back into service with the MP3 player.
So capacity may be the same, but the useable mah above a certain voltage/current seems to have disappeared.
Eneloops are famed for their longevity, not sure about how they fare with having that same nature of 'full' voltage/current.
Still happy with the performance with the Laddas. They will eventually be retired into headlamp and remote use and all the thermometers I have in the house that run on AAA batteries where those rechargeables are barely useable.
