Hello for sale is my CWF Pele Twist Titanium Flashlight Burnished.
18350 Battery Not Included. Light has Green secondaries.
Un-carried. Includes Upgrade/add factory Pelican Case and COA.
The price is $429.00 > $409.00 >$400.00 Shipped Paypal Goods & Services No Fees (USA). Will consider trades for Chris Reeve Knives Only.
For additional references I have hundreds of transactions on bladeforums, USN, and ebay 100%
PM and or Email (better) me at [email protected] for questions.
No Trades at this time. The Shipping will be USPS Priority. Thank you.
SPECIFICATIONS
3.7 volt driver
fet primary output
linear secondary output
single li-ion input only
Designed to work with the mtn mcpcb with spots for three qx-e leds (available here with leds preflowed on mcpcb) but will work with most any dual configuration you can create.
17mm board diameter
1.6mm board thickness
Programming
Specifications
3.7 volt driver
fet primary output
17mm board diameter
MODE GROUPS BASED ON RED SECONDARY:
1- low red,high red,ml,5,15,35,50,100
2- low red,high red,5,15,35,100
3- low red,ml,5,15,35,50,100
4- low red,5,15,35,100
5- low red,high red,15,100
6- low red,15,100
7- ML,5 ,15,35,50,100
8- 5,15,35,100
REVERSING OPTIONS (1/2 SECOND PRESS)
Turbo--->Strobe--->Batt Check (1-8 with 8 being full) ---> Bike Indicator Strobe
Configuration Options:
To enter configuration mode, quickly turn off the light 15+ times until it starts to flash. Once it starts to flash, you are in configuration mode.
Once in configuration mode, the light will give a solid flash between 1 and 5 times. The number of solid flashes indicates the option number to be changed.
To select/change the option turn the light off and back on during the strobing flashes that immediately follow the solid flashes. When you choose option 1 it will start to flash 1-8 times, turn off and back on after the number of the group you want comes up. When setting the temperature control the light will go from programming to turbo, turn the light off when it reaches the temperature you desire.
1. Mode Group Select.
2. Memory Toggle.
3. Mode Order Toggle.
4. Temperature Calibration Mode.
5. Reversing Toggle.
SPECIFICATIONS
3.7 volt driver
fet primary output
17mm board diameter
Programming
Specifications
3.7 volt driver
fet primary output
17mm board diameter
6- low red,15,100
8- 5,15,35,100
2. Memory Toggle.
