Rothrandir
this is something i've had sitting around for some time, but was hestitant to sell it because by nature, the thermal path of a pill isn't as good as a permanently bonded heatsink. however, i need some cash, and every little bit helps. i've decided to sell this pill for $15 shipped, provided the buyer understands that the thermal path is good, but not optimal, and that this is an old ld emitter, of unknown bin. it seems to be warmish white, but not unpleasant.
the pill works well, but because it's not perfect, i decided to either junk it or sell it for cheap. this
again, i'm hesitant to sell it, because it doesn't live up to typical rothish quality standards, i guess you can think of it as a factory second /ubbthreads/images/graemlins/smile.gif
it was designed to drop into a brinkmann 3aa, and will not fit in a minimag, as the minimag hole is smaller.
it's constructed of a metal heatsink/pill, and a solder blob to make positive connection. as with all pills, care should be taken to make sure there is a clean thermal and electrical path from time to time.
asking $15 shipped /ubbthreads/images/graemlins/smile.gif
