I was fooling around with lanyards the other day for my ARC-AAA, and here is what I came up with. It allows you to use you ARC-AAA as a headlamp similar to the Jacstrap system ™
Basically it is just a regular lanyard with the addition of a cordlock. Then you tie a slipknot into the lanyard and wrap it around the body of the light below the head. When you don't want to use it this way just slide the knot off and tug and the slipknot disappears.
Put it over your head and use the cordlock to tighten it.
Adjust for best fit, and to eliminate glare. It works well to free up your hands, I've used it to set up a tent in the dark and other camping chores.
I tried this with regular cord as well as bungie type cord and saw no discernible advantage to the bungie. For knot tying fanatics there is a way to do this using a sliding knot, anybody interested?
Warning this lanyard may not break away and could cause strangulation! Use at your own risk.
