This post was returned to the thread on 2/8/06.
I just received a bunch of Osram 62138HLX 12V100W bulbs from Specialty Optical Systems. These are Gy6.35 size but with a very small capsule. Specifications indicate that these will not tolerate much overdrive but it seems to handle a reasonably fresh (though not straight off-charger) 11-cell KAN1800 4/5A pack. That's 14.2V dropping down to 13.7V in the first minute. Not bad. You may know these bulbs as the HOLA for the Blitz 240 spotlight that Sway has done so much work with.
These bulbs have a small axial filament to go along with the small capsule. Since the overall size is smaller than the 64623HLX I based the primary Aurora design upon, the LCL (filament to base length) is also shorter and puts the bulb at the very limit of adjustment on my Aurora prototype.
So how do they work? Aside from reservations about the stated 932F operating temperature, this bulb kicks ***. The filament is small and wound tightly so that there is minimal axial distortion. This means it throws a wickedly tight and perfectly circular spot. Wow! The light color is also very pure white. Much whiter than the 64623HLX driven to the same levels. The CCT must be in the range of 3,600K-4,000K. Simply stunning. This is the new $3 wonder bulb.
I believe that the 64623HLX, when overdriven to 15V-16V will absolutely crush this bulb, but the '138 performs much closer to the edge at lower voltages and thus will maximize the punch of a smaller battery pack.
Since this bulb is not listed in the Osram online catalog, specifications are nonexistent. However, I will be doing some comparative testing tonight and return to post beamshots. One thing I do notice already is that within 10-15 feet, it doesn't seem as oppressively bright as the 64623HLX simply because so much of the light is concentrated in the hotspot. The retina just saturates above a certain level. The '623 by comparison throws a massive, winged hotspot that spreads out the light and creates a "wall" to go along with the central spot.
Look for garage and 200' tree shots with the 3" turbo head as well as pictures of the bulbs later tonight.
Wilkey
Note: I am working with Carley on a design for a deep-dish 6" aluminum reflector similar in aspect to the excellent RF2102. The initial prototype run could be for as few as 20 units in the $50 range. Think of a Vector 2MCP reflector but with 30% better collimation efficiency and the ability to be threaded for direct mounting onto a Mag body. Grotesque? Sure, but incomparable for throw with a specified 6" central spot at 500 yards. I imagine the HID boys could have a field day with this baby.
edit: corrected Osram bulb number
Wilkey
