Re: What are the flashlights on aircraft lifejacke
The main problem with the PLB and EPIRB's is they are expensive, Figure about $600 for the 406 Mhz units without a GPS engine built in, and about $900 for units with the GPS built in. The main players seems to be ACR and McMurdo/Pains-Wessex. The GPS engine on the McMurdo/Pains Wessex didn't do so well in testing, and in fact there is an unofficial recall out. If you have a GPS equipped McMurdo/Pains Wessex they will send you a prepaid return shipping container and replace the unit. In theory they are contacting owners (they got the registrant information from NOAA, so they know where these things are.)
The 406 Mhz units are big improvement over the 121.5Mhz units. A lot more powerful (5 watts versus typically 50mw), and the much better frequency stability (makes for a more accurate doppler based fix), and they transmit the ID of the beacon at the bare minimum. A couple of passes with a COSPAS/SARSAT bird is good for about +/-20km with the 121.5's, and about +/-6km with the 406's. The real breakthrough comes with the GPS equipped units. They transmit position with the beacon ID, so the alarm and the position can be picked up by one of the geosynchronous birds along with the position to raise the alarm. The result is the time from raising the alarm to having a good position (often +/- 30 meters) is unlikely to exceed about 20 minutes, whereas without the position, if you are unlucky, it can take several hours to get a usable fix. At this point the PLB's only weigh about half a pound, and are easily carried on your belt or around your neck. Suffices to say that knowing where to look +/- 30 meters makes finding the person in the water a whole lot easier.
The other advantage the 406Mhz units have is they are registered. When the alarm goes off, they know who you are from the Beacon ID, and what to look for. In fact the first thing they will do is call the contact phone numbers and make sure it isn't a false alarm, and get whatever details they can.
The 121.5 Mhz units are just a beacon, no information is transmitted on the beacon.
EPIRB's are PLB's with bigger batteries, some are self deploying (if they get under more than about 8 feet of water, they will automatically release from the mounting, and all of them will powerup if they end up in the water. They are effectively buoys with a PLB inside, many have small strobe's on board as well. They are also priced like EPIRB's, although the self deploying units tend to be a bit dearer.
