Hi.
I agree with NaCl.
Unlike AAA,AA, c, d and lithium bateries. Automobile batteries are designed to output large amounts of power in a very short time, usualy 500+amps. This is also true for those portable battery/booster packs one can purchase any NAPA/UAP or Canadian tire stores, even if they are only 300 amps.
Hense the easy way to burn out your led lights in a blink of an eye.
I 'm not certain if this will help, however.
I make LED lighting for hunting camps and chalets , for solar kits or battery packs.
I use the standard 10 grouped led heads (lamps) that are used to replace incandescent bulbs in an automobile's head lamps, or the 10-12led sandwiches (cheaper but requires better power regulation).
Basicaly it is 2 or 3 led lamps slaved to a box with individual switches with individual power regulators.
I opted for isolated/individual power regulators as the lamps will be used in an environment that has very large changes in temperature,humidity, e.t.c., and didn't care for any trouble with auto regulating IC chip based circuits. Therefore the power regulation is solid state, as well as Slow start (power's up slowly).
I'l I honestly do not know how a luxeon (1 watt) will fair
as a dome panel light. However it's a given that you will without a doubt need a good power regulator.
Also I had a thought about the automobile battery power regulator on a single 1 watt luxeon. The resistance circuit needed to regulate the charge will probably get quite hot.
However I could be wrong about the regulator heat.
Good luck
