illumiGeek
I ordered a few of the infamous WA 1160 lamps in PR base potted form. My plan is to run them in my 3C Mag host powered by 5 Sanyo CP-1300SCR high output NiCad cells. I have an Aluminum PMR reflector and a UCL lens, so I'm good to go on that front.
My question is; how will the rest of the Mag host hold up to the heat and current draw of this lamp?
Estimated run time on the Sanyos will be around 20 minutes (probably a bit less in reality). Would the Mag bulb post/switch assembly hold up for that long? If not, what would the Hotwire gurus here recommend as a safe maximum for on-off time?
Thanks!
Aloha, illumiGeek (Tim)
Thanks!
