Strange - Tristar-3 works on 123's but not Pilas
JimH
San Jose, CA
Strange - Tristar-3 works on 123\'s but not Pilas
This is a follow up post to an earlier post that I made "Tristar-3 works on c123's, but not for long".
I figured since 123's get real hot when running the Trilight-3, I would try Pilas since they handle more current. Problem is when I use 2 Pila 150a's in place of 3 123's in a Mag 3C with a Trilight-3, all I get is a momentary flash when I hit the switch, then nothing. I can hit the on switch as many times as I want, but each time all I get is a flash then nothing.
Anybody have any idea why I can't replace 3 123's with 2 Pilas for running a Trilight-3.
georges80
Sunnyvale, CA
Re: Strange - Tristar-3 works on 123\'s but not Pi
[ QUOTE ]
[/ QUOTE ]
Just a guess - based on the 'flash'. The Pila Cells have overdischarge protection (probably a resetable fuse - or maybe electronic). I'd say the current draw is so high that the fuse opens to protect the Pila and that's why you see a short flash. Then it resets. Measure the current being drawn from the Pilas into the tri-star if you can. Add some series resistance and that'll probably fix the 'problem'.
george.
JimH
San Jose, CA
George,
Looks like you might be right. I get a momentary reading fo 6 amps while the light flashes, then I have to wait 20 or 30 seconds before I can get the light to flash again.
Is there such a thing as a wafer resistor, about the size of a dime, that could be easily placed inline with the Pilas?
georges80
Sunnyvale, CA
[ QUOTE ]
JimH said:
George,
[/ QUOTE ]
The tristar is 3 Lux3's ? connected somehow?
Also, when I said a fuse for overdischarge - I meant a fuse for over-current protection.
george.
MR Bulk
Hawaii
What Is a Tristar 3 anyway?
MrMom
Tonawanda NY
Charlie I believe that the tristar is an inretec drop in. It is not regulated.
JimH
San Jose, CA
[ QUOTE ]
[/ QUOTE ]
Inretech 3x3w drop in for Mag 4D. See it here
MR Bulk
Hawaii
Ahh, direct drive. In that case I must agree w/George (of course - who would dare not to?)...
georges80
Sunnyvale, CA
[ QUOTE ]
JimH said:
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
So, how are the Lux3's wired? Inretech's site says for 4D cells; I assume 6V alkaline, 4.8V nimh, so probably in parallel (with some series resistance). You've tried to drive it with 3 123's (fresh, 9V no load) or Pila's (fresh, 8.4V no load).
If the Lux3's are wired in parallel it's no surprise the Pila's (being li-ion the can pump out a lot of current - until the protection circuit cuts out) peak at 6A. Lucky you haven't blown the Lux3's...
Anyhow, being direct drive that's a problem with changing battery chemistries or # of cells - it generally won't work.
If you want to run 2xPila's in there or 3x123's you need to rewire the head to put the 3 luxes in series, get rid of the resistance and put a boost converter in there... 123's still won't give much runtime - since you're presumably wanting to drive the Lux3's at 700mA or higher - and you'll be pulling ~1A from the 123's, so <1/2 hour of runtime. 2 Pila's into 3 Lux3's would work great with a boost and 1A into the Lux3's and ~1hour of runtime. 4D nimhs would give excellent runtime. All this would be regulated.
You can see one of my drivers with 4AA nimhs pushing 750mA into 3 series lux's (and with dimming if you want it...) cpf thread
george.
