OK I bought a green laser pointer from Optoelectronics several years ago. It had a very nice brigh output (an unqualified twice as bright as the one I got from Happaporte around the same time).
This weekend I left my coat pocket unzipped and the thing fell out onto the floor when I bent over to look at something...
I heard something rattling inside. It looked like it was still lasing green so the ND:YAG doubler crystal was OK (I assumed that had cracked).
I took it home and started to take it apart for the first time. On the tip was a pointless sort of threaded cover, I guess it could be replaced with diffraction grating designs later but I don't believe they were ever made for this particular laser.
Here's the site from the company I bought from but I have to say
http://www.eoi.com.tw/laser-2.htm
the laser I have is from around 1999 (I think?) and doesn't look like the picture. It was so long ago that the laser didn't even have the eye safety, CDRH, and other compliance on it (it got stuck in customs for a while). It was a steal at the time at $230 though (most places were US$300+)
Anyway it's much thicker than most (maybe thicker than the diameter of an AA battery).
So, under the dustcap was a lens in an aluminum threaded tube. This tube had threads on its outder diameter and it threaded into a black plastic tube that is threaded on it's inner diameter. This first lens was a convex magnifying lens.
The next lens that unscrewed was an IR filter
The next piece fell out. It was a concave lens with a piece of copper with a tiny pinprick hole on it. I believe this was glued to the output of the laser and this is what came loose when I dropped it.
The next piece is a black plastic threaded part BUT it is glued into the main tube.
I need to glue the lens/pinhole back onto this part but can't get to it because it's deep in the pointer's barrel. The electronics won't push out from the front or the back (though it will move slightly in both directions.
Does anyone know this type of pointer and how I might disassemble it further so I can fix it?
Thanks
Thanks
