Just browsing this, and from what I've seen here, it appears that you've got 12V 60mA incandescent bulbs (not LEDs) that you're wanting to drive from a source that's variable from 10 to 30 volts.
If you've been following the "hotwire" section, you'll know that the output of an incandescent bulb is VERY nonlinear with respect to input voltage - with a simple resistor setup (300 ohms is, unfortunately, halfway between 2 standard values - you'd need to go with 270 or 330), you'll be running the bulb at anywhere from 4 volts input to 12 volts. At 4 volts, an incandescent that's designed for 12 volts probably won't even have a visible glow at the filament. LEDs are much more forgiving of severe underdriving.
I can see 2 possible solutions:
1) Ditch the incandescent and go with an LED. With a red LED (typical 1.7V forward voltage), you'd need a 1500 ohm 1 watt resistor (power dissipated at 30 volts would be 0.6 watts). Or, you could use 3 470 ohm resistors (1/4 watt would be fine) in series - the slight overdrive when you're at the top of the voltage range shouldn't be enough to harm the LED.
2) Go with a regulated LED setup. Use the 7805 that's been mentioned previously, then a 180 ohm resistor to the LED (which would be running off 5 volts).
3) Go with a regulated incandescent setup. I haven't run the 78xx series in the "drop-out" region, so I don't know whether they stop delivering any output, or whether they merely do a "pass-through" with a voltage drop equal to the minimum rated "input must exceed desired output by" voltage. If the latter, get a 7812 and use it to drive the bulb. It'll be fairly dim (but getting brighter) from input voltages of 10 volts to about 14 volts (if I recall correctly the minimum regulator "drop" is around 2 volts, so at 10 volts input you'd get 8 out), but constant from there up to 30. If they don't deliver any output when input is below the target voltage, you'd need a 7808 (5 and 12 volt regulators are common, other voltages are harder to get, and definitely wouldn't be found at Radio Shack), and the bulb would be very dim all the time (1/3 underdrive). If the 7812 route won't work, you'd probably be better off ditching the incandescent and using an LED.
Note that the neon bulb in the cheap circuit tester is NOT suitable - neons don't even start to conduct at less than around 90 volts.
