PANZERWOLF
well hardly a "mod" actually ...
i decided to stop the battery rattling in my infinity when turned off, so i cut a foam ring from an old mousepad to go between head and battery, leaving a hole for the battery contact, this works quite well
a nice side effect i observed was that i could now dim the light by the degree of tightening the head to turn it on, i have noticed this before, but it was always a useless, unpredictable, flickering affair
but now, with the last 45° turn, i can dim the light very smoothly and it doesn't even flicker when i shake or drop it
beamshots (at 1m) at lowest and highest setting: /ubbthreads/images/graemlins/grin.gif
this is obviously an effect of higher resistance/"bad" contact between battery and head, and i have no idea about the effects on running time (heat loss, etc)
but it's nice for stealth operations and night vision retention, the lowest setting i managed is still enough for reading, very local navigation, stealing your sister's sweets, etc
do you think this could be incorporated into other designs with a thin resistor-pad, that lowers resistance when sqeezed (like some pressure sensors do)?
does anyone know of such a material with specs useful for flashlights?
