131,410 lux! (OddOne\'s BL-3000-fun thread)
A little update to my earlier saga regarding a new LED acquisition...
The LED, in case anyone missed it - the BL-3000 from Lamina Ceramics...
Still, a super-LED needs a driver of some sort to make the most of whatever you're using as a power source, so I did some designing and SPICE-modelling of a switching power supply. A little work in ExpressPCB's board designer and $59 later, these arrived...
Oooh, my precioussssssss....
The parts to populate the boards had already arrived - it's designed to push 2.5 AMPS into the LED for as long as a 12-volt battery can deliver enough power, so all the parts are rather high-current. Basically your garden-variety boost regulator rigged to run as constant-current instead of constant-voltage.
That giant coil is a 60uH 16A choke, and it weighs about two pounds by itself. Hey, if you're gonna build something to drive high current into what electrically looks like a near-short, you use the big parts.
That plus I can't see for crap anyway, so trying to do it in surface-mount parts is an exercise in "I'll just buy one of George's BL-3000 driver boards when he starts selling 'em."
Testing time...
Driver plus BL-3000 on a piece of half-inch-thick aluminum plate, powered by a Power One SPL250-1012 monster PSU. Used to use another of the Power Ones to run a TEC in my computer's cooling system - they're about as tough as you're going to find (and expensive as hell - $380 each new!)
Apply power and step back...
MY EYES!!!!!!!!!!!!!!!!!!!!!!!!!!11111oneoneoneeleventygazilliontotheinfinitepower
Yep, it works. /ubbthreads/images/graemlins/grin.gif
Sneak peek of the next step...
Here's the reflector the LED is going into:
I know folks here have been trying desperately to figure out how to collimate the light out of an LED that size, so here's the answer:
Reflector out of an Altman stage/theatrical light, muahahahahaha...
I have a light meter coming in tomorrow's UPS (hopefully), so I'll be able to get hard numbers on the LED running at its ideal power level.
oO
Testing time...
oO
