PhotonWrangler
Dude, I ain\'t gettin a Dell
Working on a friend's Dell laptop that's out of warranty. The symptom is that the computer claims that it "doesn't recognize the AC Adaptor" and thus won't charge the battery. So now the battery's dead, the laptop won't boot without the battery installed and it won't boot with it either.
Apparently Dell places a Dallas Semiconductor one-wire memory chip in the laptop's power supply. When the laptop boots up, it sends an inquiry through the third pin of the AC adaptor. If the chip in the AC Adaptor responds that it's a genuine Dell supply, all is well and the machine continues to boot and it applies charging current to the battery. But try to use a third-party supply on the machine and the inquiry fails, causing the machine to refuse to charge the battery.
Sorta makes sense in terms of controlling what kind of device is charging the battery. However there's been a rash of failures of this secret authentication scheme, causing many Dell laptops to turn into doorstops! Dell says it requires a replacement motherboard, to the tune of around $600.00! /ubbthreads/images/graemlins/mad.gif
So now I can't charge the battery and I can't run it off of AC, even though the AC adaptor is making DC power. I have to find another similar laptop to charge this battery so that I can try to get the machine running long enough to apply a BIOS patch that might help. But I can't apply the #!@$ patch because I can't boot the &^%! machine!
And from what I've read on Dell's own support forums, this is apparently a pattern failure with certain models of laptops, yet there's no recall, not even an apology, and they're continuing to charge hundreds of dollars tro replace the MoBo (which presumably disables or modifies that "AC Adaptor Authentication" scheme. AGH!
/ubbthreads/images/graemlins/mad.gif /ubbthreads/images/graemlins/smoker5.gif /ubbthreads/images/graemlins/knight.gif /ubbthreads/images/graemlins/sick2.gif
Thanks for listening
