lightlover
QUOTE - "If a quartz halogen bulb is touched, it should be cleaned with alcohol to remove any traces of grease. Traces of salt will also be removed if the alcohol has some water in it.
It is generally not a good idea to touch halogen bulbs, especially the more compact, hotter-running quartz ones. Organic matter and salts are not good for hot quartz. Organic matter such as grease can carbonize, leaving a dark spot that absorbs radiation from the filament and becomes excessively hot. Salts and alkaline materials (such as ash) can sometimes "leach" into hot quartz, which typically weakens the quartz, since alkali and alkaline earth metal ions are slightly mobile in hot glasses and hot quartz. Contaminants may also cause hot quartz to crystalize, weakening it. Any of these mechanisms can cause the bulb to crack or even violently shatter. If a quartz halogen bulb is touched, it should be cleaned with alcohol to remove any traces of grease. Traces of salt will also be removed if the alcohol has some water in it.
Since the hotter-running quartz halogen bulbs could possibly violently shatter, they should only be operated in suitable fully enclosed fixtures."
See Halogen Bulb Failure Modes @ http://www.misty.com/people/don/bulb1.html#hfm
So, for cleaning incandescents, I should add some distilled water to my Isopropanol bottle ?
What's de-ionised water ?
lightlover
[The great Don kindly says:
Copyright (C) 1996 Donald L. Klipstein (Jr) ([email protected])
Freely distributing copies of this entire document or un-HTML-ized text versions thereof is permitted and encouraged.]
lightlover
