Steelwolf
I'm designing a mod for one of my favourite flashlights and I've kind of hit several snags. It has a 6V power source which can be reduced to 3V if necessary.
Firstly, the NexGen stuff from Sandwich Shoppe says max Vout from the module is 6V or Vf, whichever is lower. But electrical characteristics of LuxV, according to the LumiLEDs datasheet, says that at 700mA, typical Vf is already 6.8V.
Does it mean that if I hook up a LuxV to a NGBB917, I will not achieve 917mA in to the Led until the LED heats up and its I/V characteristics change? (Sort of like thermal runaway begins but is halted at 917mA.)
Will I be overpowering the NGBB module by using 4 C-cell alkalines, and can the module handle it without damage or degradation?
Also, I'm deciding whether to use LuxV or LuxIII. I naturally want this to be as bright as possible. I'm making provision to swap out the emitter when the luminous flux degrades. The focusing and beam spread is not under my control, as I've already decided to use the 2deg optics. Heat dissipation is probably as good as it gets with a solid Al head and cooling fins, but will be the same regardless of emitter used.
Looking at 700mA specs, the typical luminous flux of LuxV is twice that of LuxIII. Even at 1A going in to the LuxIII, a 700mA LuxV is still 1/3 brighter and the nominal specs suggest that the LuxV still has slightly better luminous flux efficiency (lumens/watt). (Am I right?) However, we all know that heat generation will skew those specs quite a great deal.
So, at nominal 700mA, which package runs hotter? What about at 917mA?
Will the amount of heat generated result in the relative efficiencies to change such that the LuxIII is now more efficient than the LuxV? Remember that the heatsink does not change.
And in your opinion, is the extra cost of the LuxV over the LuxIII worth it for the extra brightness? What about when the severely reduced lifespan (500hrs vs 50,000hrs to 50% brightness) is considered?
Thanks.
Thanks.
