SilverFox
Now that summer is almost here… I thought it would be interesting to see what effect cold temperature has on the Lithium CR123 cells. /ubbthreads/images/graemlins/grin.gif
We recommend lithium cells for cold weather use, so here is a look at how they perform in the cold.
Harry N sent me some Varta cells with instructions to check them cold. Thanks Harry.
I did a normal room temperature run at 0.5 and 1.0 amps, then took cells and put them into my freezer. I checked the temperature of the freezer at 0 F., and let the cells sit there overnight.
I have a cold pack that I formed to cradle the cells for testing and pulled them from the freezer and immediately tested them. I put a hot pad around the cold pack/cell to keep the temperature stable.
The test at 0.5 amps is really strange. The cell temperature was trying to increase, and it seems that the chemistry was unable to keep the reaction going. Very strange graph, it jumped around a lot. At the end of the test, the cell temperature was 56 F.
The test at 1.0 amps also showed some quirks. There was a dip about 2/3 through the test, then it is as if things recovered a bit, then it dropped off, then the slope tapered off. All of these changes seem to be temperature related. This test was a lot smoother than the 0.5 amp test, but the cold temperature still seems to take its toll.
At the end of the 1.0 amp test, the cell temperature was 77 F.
While lithium chemistry is more reactive at higher temperatures, it does a pretty good job at low temperatures as well. It seems that lights with higher current draws perform better than lower current draw lights, and you may notice some flickering with a low current draw light.
Here is the data.
Tom
Here is the data.
Tom
