AA or Artic Alumina makes both contact grease and expoxy. Common use of AA in posts without noting which one is confusing.
My favorite way to attach stars is to use AA grease to entire bottom surface. then use a small drop of superglue to edges. glue will wick around edges. then hold down firmly for 1-2 minutes and you are done. VS need to clamp down while AA expoxy sets.
mechanically attaching stars by screws works well. apply AA grease here too. most surfaces are not perfectly flat.
object is to make complete contact with two surfaces ending up with thinest possible layer.
if done correctly, attaching emitters with same technique allows removal later without damaging emitter. object is to cover completely metal slug of emitter with AA grease without getting on plastic edges.
really anal folks will lap surfaces before aplying AA /ubbthreads/images/graemlins/icon15.gif
