cgpeanut
I have 4 brand new Latetest POP2 Version 2.25 Q3 Modules with TWOJ single LDO and 1 R2GH Red-Orange POP2 Version 2.25 for $59.95 each,
These have the thick copper heat sink for proper thermal path and acts as a drop in module for your Nuwai Q3.
Red-Orange POP2 V2.25 Q3 Beamshot Really Bright! R2GH bin Lux III 190 Lumens! Fred Advertized /ubbthreads/images/graemlins/smile.gif
TWOJ POP2 V2.25 Q3 Beamshot Best Balance between brightness and runtime
These POP2 V2.25 Q3's are configured with 1 LDO using TPS73601
First to post "I'll take it" here, takes presidence over pm's
$59.95 shipped anywhere, I'm now giving away the copper slug that was made by a fellow CPFer from India /ubbthreads/images/graemlins/grin.gif as a promo for the 'Weekend Special'
paypal address: [email protected]
Runtime on these are less than 2 mins just enough to test all the functions.
They were designed to go into the Nuwai Q3.
For more info on what the POP2 is all about please check this thread posted by DJPark.
POP2 (PIC-O-PWM V2) with PICmicro Dual UI
Features
- LDO based constant current regulation with li-ion battery
- Dual selectable UI (traditional and simpler version)
- 7Hz Strobe mode (instead of previous 5Hz).
- Easy access to the default high and low brightness mode
- Last brightness level used is remembered when turned on next time
- Modified SOS mode (shorter pause between characters)
- survival mode with minimum current flow and lowest brightness for really long run time
- User selectable low mode brightness level
- optional burst mode for short duration brihter light output
- Provision for future firmware upgrade without replacing the controller IC
Features
