[ QUOTE ]
Size15's said:
Firstly, there is no such thing as "HA 2" or "HAII"
Level III is Hard Anodised.
Second, if the Hard Anodised is dyed then it will not be as hard as natural HA althought my understanding is that even "HA" is not raw in most cases.
I don't consider Black HA to be as durable as 'standard HA' although this could be because wear is more obvious (contrasting) when the HA is black.
Al
[/ QUOTE ]
Hi Al,
For this side of the pond, Hard (natural) anodize is Type III, class 1. When dyed it is Type III, class 2. For "natural," it can be applied as a "flash" (what I would call the finish on my Li-Ion Heart) to serious depth/thickness up to about .003" which, IMO SF uses. (The anodizing process both penetrates and builds-up- the latter can play hell with close tolerance, threaded fits!) As I understand it, dying hard ano doesn't soften it, but I'm not the final word.
Type II, class 2 is what is seen on gaglites. (With the exception of "silver" which I think is class 1. (Undyed)) The "hardness" of the underlying aluminum alloy greatly affects the durability of the finish.
Non-dyed anodize finishes (class 1) frequently have a sealant applied to prevent them from adsorbing stuff later which could result in discoloration.
Of course, you are well aware that both SF and
G@gs are made of
Dural. /ubbthreads/images/graemlins/grin.gif
Larry
