connortn
I have decided on flashlights for the autos and have a G2 for home. The G2 doesn't have the lock out feature so I'm not comfortable carrying or packing it. I think I'll go for the E2e for the times I may carry (and leave the G2 at home) and would like you fella's to explain the way more clearly unto me about the possibilites of using different batteries and lamps to get the same output (or a little more if it works out that way) with the best even output over the same time (or a little more if it works out that way again).
I've gone through the threads about changing/modifying bulbs and going to rechargable batteries on the E2e but there's a lot there and I'd like the info in one place if possible. From what I can grasp, the E2e operates at 6 volts (3+3 volt non-rechargable 123 batteries) with a 60 lumen bulb that is different from the P60 bulb at 65 lumens in the G2. It looks like the mod is using rechargable batteries that after a short "on" time are settleing down to 3.7+3.7 volts = 7.4 and replacing the standard E2e bulb (which I assume is rated at 6 volts) with one of higher voltage rating to compensate for the 7.4 volts the new batteries are putting out. This evidently comes at a cost of having to use a non-standard E2e bulb seat that will fit the E2e but needs to be slightly modified to fit a different higher rated bulb.
Right so far? :huh2:
What I don't get is, is this mode only to use rechargeable batteries? I'm not particularlly interested in rechargeable's since my hopefully soon to be E2e will not be used enought to concider that option, but if the mode would give me a signifacant increase in output stability (since the E2e isn't regulated for constant lumen output as is the A2) then I "would" be interested. I'm not up on the characteristics of rechargeable batteries and so don't know if there's something going on here I don't know about. I don't wish to give up any run time with this mod if used so that would be a consideration also.
So, to make this mess a little more clear (too late for that, huh?) I'm interested in a mod for the E2e that will give me a more even lumen output "without" losing runtime, or the rated 60 lumens and without adding any length to the unit with add-ons. As I said, rechargeable batteries aren't important to me but if I have to go to them to get what I want then that's OK too.
Think it over and let me know if it's possible, even if you have a different solution than the original one.
Thanks again...
Connor
Thanks again...
Connor
