Geogecko
I have been interested in designing a custom LED bike light, that would incorporate one of Lamina's BL3000, with possibly the 60 degree optic on top of that. The only other consideration is a custom reflector.
I have not been able to get a good idea of how much something like this would cost to the end user. But, a single BL3000 is around $80 or so, and I'm guessing custom aircraft aluminum with anodizing would be in the $40 to $80 price range, and then the electronics to drive the LED. I'm assuming the electronics would be the cheapest part.
The battery pack would probably need to be sold with the light, or a rather common connector would have to be used so that people could design their own batteries. I was considering using a battery pack that was off the shelf. I'd like to use a current bike companies' battery pack and charger, but buying those parts from them would be expensive, and probably not in their best interest. The battery pack would probably need to be on the order of a 11.1V Li-Ion, capable of supplying 8-10Ah of capacity.
I would expect a light of this magnitude to cost around $250, by the time everything is done, maybe $300. Keep in mind; this is the light head only, no battery pack or charger included in that price.
The electronics would consist of a constant current driver, with probably a boost type regulator. The Vf of the LED is 11.3V @ 2.3A, and puts out about 567 lumens. The microprocessor would be able to control several brightness levels, to allow for longer run-time, or for less light output when using the light on lighted streets, for example. I would imagine about 4-5 different levels of light. Also, a battery meter feature, that would include a battery level indicator (series of LED's on the back of the light), and a shut-down sequence when the battery gets low.
I'm trying to see if there is any interest in this, as building just 5 of them is rather expensive, but building 100 or more brings the cost down a bit. (Especially with the custom enclosure.)
So, what do you guys think? Based on if you liked the enclosure, and all the features, would you consider this light over one of the leading manufacturer's of HID bike lights, or LED bike lights? This isn't really a reality yet, just an interest of mine. If there is significant interest, I may get pushed more into doing something.
This light should be more than enough for road biking and probably just right for mountain biking. I currently have a Light & Motion ARC Li-Ion, and I'd say it's bright enough for mountain biking, and it claims 675 lumens.
