is there any diff. between using a regular diode (tan with the colored bands) and using one that is grey with markings? (the gray ones feel like rough ceramic). I'm thinking one dissipates heat quicker.
Thanks.
Vas
Thanks.
Vas
vasdef said:is there any diff. between using a regular diode (tan with the colored bands) and using one that is grey with markings? (the gray ones feel like rough ceramic). I'm thinking one dissipates heat quicker.
Thanks.
Vas
vasdef said:I've built a bunch of LED lights in the past year or so, I've never had a problem until I tried these gray diodes. What I don't know is anything about the diff. types of diodes. The tan ones I mentioned are (to me) the run of the mill ones you get at Radio Scrap. So when I needed 10 ohm, 1 watt diodes this time, I sent for them from Mouser. I don't remember what type they are. I built a light using 18,000 mcd LED's from superbrightled.com and one by one, each bulb fried. I've used these LED's for other projects, but never had a problem. I guess I need to do some diode homework.
Thanks for the replies,
Vas
