I received my order, 11 days after the order was placed. Somewhat of a mixed bag.
The two lasers work just fine and are freakishly small, using the AG3 rather than AG13/LR44 cells. The entire laser (except the keychain, of course) will actually fit into an AAA flashlight and I will probably rig one up to work on an LiON cell in a 2xAAA light just for battery reasons.
I also ordered one of the 3LED LR44 lights and one of the 5LED LR44 lights and though both are new in package, neither works intended. The 3LED light works if you hold the switch down, but it's a clickie and shouldn't need this... but I'll probably give it to a kid and the 'defective' switch will probably be a blessing but the 5LED light doesn't work at all. If I remove the batteries, and reinsert them, as I start to screw the tailcap down, the light flickers two or three times, but does nothing consistant and nothing when screwed down all the way. Spring looks stright so I don't know what the deal is... I'll play with it some other time.
The USB cable works perfectly... but it hasn't seen ANY rought use at all so I'm not sure how the internals will hold up.
Overall, I'm disappointed in the LED lights, but I still got two laser pointers and a USB cable for about $12 so that's not really all that bad.
