My new Red Lens cover for ARC AAA
Blue72
Here is a pic of my new red lens cover for my ARC
I was playing around with some RED nichia CS LED's. but the problem was I did not want to carry two flashlights with me So I made this lens cover.
It was Easy. I took a 1/2 inch screw cover from Home Depot and punched a hole using a solitaire flashlight head and a hammer. You can also use the ARC battery tube if you do not care about scratching the anodizing.
I then used the same solitaire head and hammer to punch out a lens from a piece of clear plastic that I cut out from a flashlight package.
I used the solitaire head again to punch a template in a pair of 3-D glasses that I had and used a pair of scissors to cut it out.
I then glued the red cellophane to the clear plastic lens that I made, dropped it into the larger opening of the screw cover and glued it in place.
By the way there was no damage to the solitaire head.
There you Have it!!!
And you can use the other 3D lens for blue! haha. That's awesome!
actually it made a nice blue/green cyan! :)
I do not know what I would use the blue/green for, but it looks cool.
