andrewwynn
Inadvertently i discovered a way to 'hack' a hotdriver into submission to make it work in an M6.. you'd be able to use 6xLiON in a 2x3 config or 6xNiMH 'A' diameter in a series config (a little more work to make the end-caps for series). The beauty is i don't need to make a new driver board and the end-caps especially for LiON use can be made with just circles of PCB. (actually on one side i'll just use a piece of copper to keep the thickness down).
I have a loaner lined-up to perfect the solution and when i have the solution complete i will post a 'who wants one' on BST. There is a fair amount of labor involved to make the hack (cutting traces, a jumper or two).. but it's reasonable and i think i'll be able to offer a complete pack with 6 LiON for under $100, hopefully that will even include the modified tail cup.
I will also show the 'cookbook' so somebody with the skill can just buy the hotdriver and make the modification themselves, probably save about $30.
here's the hotdriver
here's the battery pack that it will go on (orange).. shown with a stock M6 MB20 battery pack.
the M6x6 will run nearly 40 minutes in an M6, probably 30+ minutes of that is in regulation.
My favorite part.. it looks like i can work out voltage and current regulation, so that it will run the HOLA or the LOLA with no changing of any settings.. just fully automatic!
-awr
-awr
