I have recently aquired some small peltier junction chips, 1-5v, 4-6w. One of these thermoelectric devices would easily fit onto the metal PCB of a luxeon or similar LED, possibly two of them.
Problem:
As you run a 1 watt LED at higher and higher wattage, more and more of the electrical input would be turned into heat rather than light tending to damage the LED.
Calculation:
(Note, this calc is not based on real numbers, just a hypothetical situation.) Say your 1 watt LED is being driven at 5 watts, and has the low efficiency of 40%. This means you are getting 2 watts of light and 3 watts of heat (negating electrical resistance of the connections etc).
Solutions:
1. Use a higher wattage LED. However, this isn't always possible.
2. Get a bigger heatsink. Also, not always possible.
3. Use Peltier cooling. This requires a substantial increase in electrical energy, a bigger heatsink and potentially a lot more circuitry. However, for "wow" lights or other unusual applications I can think of, this is potentially a good idea.
Comments:
A patent was recently awarded for a peltier cooled lighting system, complete with temperature sensors etc (The PDF has diagrams). However, this is for stage lighting, not flashlights, which makes sense.
I will play around with this idea today, but would love to hear feedback on this idea. :anyone:
Problem:
Calculation:
Solutions:
Comments:
