[size=+7]
Hi folks,
Here are more of 1D M*g with amazing brightness and many battery configuration option in gun metal gray HAIII, red HAIII, Nickel plated or gold plated finish similar to 4AA in 1D M*g but designed for 3P/2S R123 lithium ion batteries for 7.4 volt operation. Shorter than 700L but brighter.
Body is shortened to 1D and bored out in 3 slots to accept 3 li-ion 123 accross. 3 parallel/2 series (7.4 volt, 2250 mAh)
Outside body is CNC machined for great look and sure grip (Please look closely). Head is also reshaped to conical form for unique look and very fine finned for better heat dissipation. Completly deanodized, polished and reanodized in hard type III gun metal grey color, red HA, nickel plated or gold plated.
Battery holder designed to accept 6 li-ion batteries sold here which are slightly gapped to avoid shortage in case battery cover is torn. It has extended charging jack to recharge batteries with removing tail cap but no need to remove battery holder from flashlight. You can also recharge the pack out of flashlight or simply remove batteries to recharge and balance individualy. This battery holder has very low resistance and capable of high drain bulbs up to 4A with single click. Center pin of charging jack is positive and I will include a male charging jack too.
Lithium ion batteries have very low self discharge and don't need to top off very often.
There are many bulb options such as:
WA1111 for over 900 bulb lumens.
CL1057
ROP LO
And many more.
Moders also can use it as multi cree host.
It is also possible to use 6 primary 123 cells if you need that 10 years shelf life for emergancy use. In this case, bulb option will be WA1183, WA1319, FM axial 4 volt and 4 cell (6 volt) drop in M*g LED.
This flashlight comes with stock reflector, lens and stock bulb. It is highly recommended to use aluminum reflector and boro lens when using high power bulbs.
Price:
Gun metal gray 1D M*g11 with battery holder $135
Red HA 1D M*g11 with battery holder $135
Nickel plated 1D M*g11 with battery holder $145
Gold plated 1D M*g11 with battery holder $165
Extra battery holder $38 each
Gold plated ceramic socket $30
MOP or VLOP cammed reflector (8mm opening) $25 each
Bi pin WA1111 $9 each
Bi pin FM axial (4 volt) $10 For primary cells only
Potted FM axial (4 volt) $12 For primary cells only
Potted WA1319 (4.8 V) $10 For primary cells only
M*g 4 cell 3W LED $15 each For primary cells only
Boro lens $5.50 each
Shipping $8 for 1 set and $10 for 2 sets in States.
Shipping $12 for 1 set international destination.
Please pick an available and valid number, post your order here for ducumentation followed by Paypal and indicate detail of your order and your CPF handle in Paypal note.
Example: :paypal: for #34 Red HA 1D
Paypal: DO NOT PAY
Discount: $10 less paypal fee when paid by USPS MO.
Please PM for different type of payment.
Any comment welcome.
#1 Gray HA 1D M*g11 Lips paid shipped
#2 Gray HA 1D M*g11 rcnuk paid shipped
#3 Gray HA 1D M*g11 Sway paid shipped
#4 Gray HA 1D M*g11 FlashInThePan
#5 Gray HA 1D M*g11 tanasit paid shipped
#6 Gray HA 1D M*g11 Flash Harry paid shipped
#7 Gray HA 1D M*g11 Flash Harry paid shipped
#8 Gray HA 1D M*g11 Flash Harry paid shipped
#9 Gray HA 1D M*g11 LuxLuthor paid shipped
#1 Red HA 1D M*g11 choppers paid shipped
#2 Red HA 1D M*g11 LuxLuthor paid shipped
#3 Red HA 1D M*g11 plasmaman paid shipped
#4 Red HA 1D M*g11 larryk paid shipped
#5 Red HA 1D M*g11 KenAnderson paid shipped
#1 Nickel plated M*g11 plasmaman paid shipped
#2 Nickel plated M*g11 larryk paid shipped
#3 Nickel plated M*g11 jaybiz32 paid shipped
#1 Gold plated M*g11 Lips paid shipped
#2 Gold plated M*g11 rcnuk paid shipped
CLOSED
[/size]
Hi folks,
CL1057
ROP LO
And many more.
Price:
Paypal: DO NOT PAY
