P60 DROP IN WITH P7
DocD
guildford england
hi,
A bit of a lose end today so modded a sccP7 into a P60 drop in for my trustfire TR-C1 it's direct drive from a 18650 blue trustfire battery it draws 2.1amps has a small doughnut hole in the beam but got to say quiet bright as soon as it's dark i'll put some beam shot's up!
Ok a bit more info it's a c bin using 6amp wire (this is way to thick) removed cree led from std one that comes with this, had to grind away some of the top wall, and fix with arctic alumma thermal adhesive, removed all componets from driver, drill and solder wires from P7, filled void thermal grease and resolder back to the under side of the drop in
using a hand tapperd reamer open the hole to except P7 check it with a fluck 83 to make sure all is ok
other photos are P60-cree R2 rated at 225lm
here's some photos cheers DocD
cree r2 at 30 feet
sccP7 at 30 feet
I like this mod. I'm hoping that Surefire will release something similar but I guess it would have to be driven at a lower level and have built in thermal throttling before SF would release it. There was talk of a P61L but this will probably be single die.
Nice pictures but the last two don't look like they were shot using the same exposure. The brick wall is darker in the second one.
Nice mod, a few people have been looking for something like this, maybe you can make a few and earn some money off of this.
i don't it's possable to make these as a sellable thing led $25.00 dollars,reflector $4.00 dollars bit's and pieces 2.00 dollars making this a $31.00 dollar drop in as a direct drive with PCB say 4.00 dollarsbumps it up to $35.00 dollars any thought cheers docD
A P7 P60 dropin? I think you could easily sell it for $60
hi jag i,m getting adout 30 mins in two 15mins runs temp gets two 40 very quick :thumbsdow just waiting some more P7's i'll make a custome sink and sleave so it run longer if this work out, i may make ten see if any one want's them, good for dark rooms and short range no throw 15 meters or so :thumbsup:
cheers DocD
Any luck docd? i would love one if you make them, but if you dont i may have a few questions about making my own. :grin2:
Im interested in one of your P7 dropins
Doc are you in the UK ???
Excellent! I just had this idea yesterday. I see you beat me to it. :)
I will probably still go one of these but not DD.
cheers DocD
The runtime should be better off 2x18650.
yep to much voltage two 18650 add up at 7.2v this woud fry the P7 the 15min use is because of temp and not the life of the battery but it a good idea thanks DocD
