TKO
- Joined
- Oct 21, 2007
- Messages
- 204
The Sleeper
We are issued 5D's as a back up to our SL-20's at work. Like it's owner the 5D was a bit heavy and none to bright, so I decided to play a bit.
I took a couple of measurements and figured that five A123's would just fit in the barrel of the light.
After purchasing the cells, I ran to a local hardware and found that 1” Schedule 40 fit the inside of my 5D like it was made to be there and that the A123 fit inside the pipe with their provided cardboard covering off. So, I had my carrier.
I had a local shop shrink wrap the cells. I then cut the PVC to a length just long enough to allow the tailcap to tighten the whole way down while leaving a couple of millimeters space, so I wasn't compressing the switch and threw it together for a test fit . . . no rattles or movement at all:
I then, shamelessly, stole RichS's modification of Northern Lights original tailcap modification:
To finish the build I added one of AW's three level soft start switches, a FiveMega MOP reflector, a Borofloat lens and an Osram 150W 64633. I then topped off the A123's on my BC-6 charger threw the switch and WOW!
Some observations:
Five A123's weigh about ¾ pounds less than five alkaline D's. (70 grams vs 139), so this thing feels like a completely different light.
The 64633 floods like nothing I have ever seen. It is amazing the area this thing covers with white brilliant light.
This thing will light off dark print newspaper in all three gears.
Charging at 5 amps takes no time at all. I giggle with amazement when the BC-6 chimes to let me know that the cells are ready.
The A123's are amazing! There is no visible dimming and they hold the same level of light because of their flat discharge curve, so this light seems regulated. When things dim, the cells are around 2.9 volts and it is time to charge.
Many thanks to Lux for his research into what the various incandescent bulbs can handle, to Northern Lights and RichS for the tailcap mod, to FiveMega for a great reflector and to AW for his fine switch (and for telling me that I had the cells in backwards, dooh!).
Time to go burn some more stuff!
BEAMSHOTS
Okay, here are some comparison beamshots taken at 7ft:
Cocoa colored wall
Malkoff M60F
WA1164 @ 1300 + Lumens
The Sleeper at 7000 + Lumens (white thermostat disappears:thumbsup:)
