Pila spacer 20 cent fix
stuff
Hello guys. I'm really excited just got my Pila charger in the mail today and my AW RCR123 should be here friday. I know that I need spacers for the RCR123 to fit. I took a stack off about 10 pennies and they look like they will work. If I clean them up good so they make contact really good does anyone see a trouble with that? If so other suggestions?
Try dimes, they have 91.67% copper. Penny has 2.25% copper. Actually pennies will work ok, just better conduction with dimes.
Bill
If you're going to use pennies, use the pre 1982 ones. They have a 95% copper content. I've used solder a few stacks for an excellent thermal & electrical path.
However for your application, I'd go with Bullzeyebill's suggestion with the dimes for their smaller diameter. They will fit in the charger better.
Hope that helps,
AZ
Hope that helps,
AZ
2+ dollar fix now. LOL
Can I Use Coins as a spacer for a PILA charger?
Coins as a spacer for a PILA charger I am going to buy this week to charge AW protected RC123's? If so is one coin preferred over others?
