Sold/Expired FS: JET I Pro - UV version
Britelumens
SINGAPORE
FS: JET I Pro - UV version *SOLD*
Hi Guys,
This very small JET I Pro from JETBeam is modded with a CREE UV emitter Q5 (wavelength 395nm) spilling very intense UV hot spot like no other with good throw too. Thanks to the reflector profile from the stock reflector.
It was modded a couple of months back and almost forgotten I had it. I still have a handful of the stock JET I Pro and its possible to have it build again.
This build maintain all functionality of the JET I Pro UI.
Excellent for forensic work, scorpions hunters etc...
Here are the specs for the stock unit. They are identical except the emitter.
Uses ONLY 1 AA battery in UV version.
Specification :
Model: JET-I PRO I.B.S.
LED: CREE UV @ 395nm
Max Output: 225 Lumens (Torch Lumen)
Reflector: OP aluminum reflector
Lens: Sapphire crystal
Material: T6061 T6 aircraft aluminum alloy
Finish: HA III Military grade hard annodized
Battery: one AA battery or any other batteries of the same size
Input voltage: 0.7-4.2V
Switch: Reverse push button switch
Waterproof: Accord to IPX-8 standard
Dimension: Bezel diameter 25mm, Tail diameter 19mm, Overall length 100mm
Weight: 50g
Output & Runtime:
AA Battery
Max Output: 130 Lumens, lasting for one hour;
High Output (Default Mode A): 110 Lumens, lasting for 75 min;
Low Output (Default Mode B): 20 Lumens, lasting for 3.5 hours;
Minimum Output: 2 Lumens, lasting for 45 hours;
Rechargeable lithium Battery
Max output: 225 lumens, lasting for half an hour;
High output (Default Mode A) 180 lumens, lasting for 45 min;
Low output (Default Mode B) 20 lumens, lasting for 8 hours;
Minimum Output: 2 lumens, lasting for 50 hours;
Example of UV use in identifying notes.
Price is $old only , please add $10 for shipping world-wide
Registered mail please add $2.00. I'll be responsible for lost or undelivered mail should you decided to choose this option.
I'll not be responsible for lost mail shipping via regular airmail. Please allow 9 - 11 working days for it to arrive.
First to post " I'll take it, get it" follow by PP to info (at) britelumens. com get it. Thanks.
With regards,
Jo @ Britelumens
Those are great looking Jo if I had not put one in a 1PD I would be all over those so instead how about a BUMP
Dave
Hi Jo,
just helping bump a fellow sgpan thread :)
any chance you are able to build an Aleph 3speed engine with a Cree UV 395nm? :D
cheers
