TakeTheActive
TTA's "Summarized" La Crosse BC-700 / BC-900 / BC-9009 Charger/Analyzer Instructions
After a few years of use (I bought my BC-900 v33 in December 2006), I call the procedure QUIRKY instead of BUGGY. :D
IMO, there are *TWO* ways to program a La Crosse BC-700 / BC-900 / BC-9009:
NOTES:
0697 Views - 08/13/2010 @ 04:28
* * * How to 'Program' Your La Crosse BC-700 / BC-900 / BC-9009 Charger/Analyzer * * *
- ALL SLOTS AT THE SAME SETTING:
.- UNPLUG the charger
- INSERT all cells
- PLUG in the charger
- MOMENTARILY press the CURRENT button to select the desired Charge Rate
- PRESS & HOLD the MODE button until the MODE changes; then MOMENTARILY press to select the desired Mode
- WAIT... after EIGHT seconds the display will change (as if you pressed the DISPLAY button). FIVE seconds later it will FLASH ONCE.
- ***DONE***
- SOME/ALL SLOTS AT A DIFFERENT SETTING:
.- PLUG in the charger
- INSERT a cell into Slot #1
- MOMENTARILY press the Slot #1 button (display is now flashing)
- MOMENTARILY press the MODE button to select the desired Mode
- WAIT... the display will continue to flash EIGHT times, then stop. FIVE seconds later it will FLASH ONCE MORE.
*NOW* you can move onto to the next cell. - INSERT a cell into Slot #2 (or #3 or #4)
- MOMENTARILY press the Slot #2 (or #3 or #4) button (display is now flashing)
*NOW* you can move onto to the next cell. - etc...
- ***DONE****
__________________________________________________
NOTES:
- The FIRST Charge Rate selected in Method #2 becomes the MAXIMUM Charge Rate for the remaining slots. So, always insert and program your HIGHEST Charge Rate cell first.
BC-900 / BC-9009 Owners: Remember - 1500 and 1800mA are ONLY available in Slots #1 & 4 (and disable Slots #2 & 3).
. - The '8 Second Timer' RESETS after each CURRENT or MODE button press so you can 'keep thinking' as long as you want as long as you keeping pressing either button at least once every 7 seconds. DON'T TOUCH ANYTHING during the final '5 Second Countdown'!
. - After a few years, the CURRENT / DISPLAY / MODE buttons start to 'Bounce' (i.e. One PRESS results in MULTIPLE changes). Get used to it! ;)
