I've been looking at leds and i guess most of them run a 3w at 1.8w so they last. Would a 100w chip run good on a 80w driver and would it hurt lumens or how do i or can i turn down driver on 100w driver to run at 90%? if it runs max current at 3.5a would it be better to get a driver with max current of 3a so leds last longer?
A good rule of thumb with any electronic component (LEDs no exception) is to never excede 80% of any maximum rating. if you want it to last forever, such as in a vehicle or similar application, never excede 60% of any rating. The one most people underestimate is temperature. Temperature builds up quickly, especially in a sealed enclosure. If you are using a sealed enclosure, try to go with a metal one, and clamp the wall of the enclosure between the LED base and heat-sink, with the heat sink outside the enclosure, taking care to remove paint from all sandwiched surfaces and also using thermal paste or adhesive between all surfaces of the sandwich. Get a cheap multimeter with a thermocouple probe and test the temperature of your creation, as close to the LED as possible, running for the maximum time you would ever conceivably use it, on a warm day. That's the way to make bulletproof designs.
