Klem
If you use a nut to hold it in place then you only need to seal it...So, a squirt of polyeurathane glue like Sikaflex will work. If you're just going to use a shallow bolt without nut then you need to not only seal it but also fix it in place...So JB Weld.
Truth be known polyeurathane will also hold it in place well enough, and I like the flexible cure of it.
JB Weld is nice and strong.
Up to you
I'd only put the JB Weld in the join/gap...The bolt is solid metal and needs no coat of glue
Up to you
