14280 battery charging in VC4
bigburly912
Virginia
Is there any reason I couldn't use a piece of brass or copper wrap it in electrical tape and charge a 14280 on a VC4 charger? I'll monitor it of course. I just have no charger for the battery and I have a few guns needing bore sighted. Can't find a primary anywhere near me
hamhanded
PNW
14280 is a small battery. If you can set the charger to use the 100 mA rate, it should be fine. I don't know how the VC4's "intelligent charge rate" feature works but I wouldn't trust it to get it right.
bigburly912
Virginia
That's what I'm kind of afraid of. If you put 3 other cells in it drops the charge load signifantly. With a craptastic wall wart I could run it with a pretty slow charge. Desperation.
hamhanded
PNW
I just checked the manual. If there are no other cells in there and you use the CH2 slot, the minimum is 500 mA, way too much for the cell.
bigburly912
Virginia
I highly doubt it will even let it try. I was gonna try to use a half amp wall wart and 3 other cells in it but oh well. I'll just keep searching for some primaries.
