They do help out a lot, especially the ones showing the warm white Quark LED to an incandescent light.
Yeah, it didn't occur to me until I posted the review that the more useful comparison beamshots would be the ones that compared with the real incandescent - my comparison with the SureFire 9P wasn't quite a mere afterthought - but wasn't exactly high on my priority.... (confessions of a doofus reviewer).
So to make up for my lack of true foresight -
Here are side-by-side comparisons with more well known real incandescents which hopefully many can related to - or even own......
4Sevens Quark AA-Warm vs. Streamlight Scorpion - Xenon 2x CR123
quick word about this comparison beamshot - although I deliberately chose a level on the Quark Warm to be as close to the incandescent compared to - I wasn't looking to compare brightness levels - but whatever I felt was the best level to compare the color/tints -
thus although the next level up 4 - High (85 lumens) would have been more appropriate for comparing brightness - the Quark Warm has a much narrower side-spill and therefore much more concentrated - ie: brighter, that the comparison of tints/color would not have been as good as at level 3 - Medium which is only rated at about 22 lumens, and we all know the incand Scorpion is rated much closer to real OTF 60 lumens - as the -2 stops underexposed shot shows the Scorpion is much brighter.
Having said all that - it is still somewhat hard to compare the tints - simply because of the really wide side-spill of the Scorpion - look carefully at the full exposure beamshot and one can see its side-spill actually encompasses and overlaps the entire hotspot of the Quark AA-Warm - so the area to concentrate on to compare the tints is actually quite small - where there is obviously no overlap of beams - that is toward the bottom left where the beam side-spills intersect to form like an X - look at the 9 and 3 o'clock quadrants to compare the side-spill of the Quark AA-Warm and that of the Scorpion respectively.....
Hope that was clear enough .....
don't make me have to draw it out for you....
ah, well -
hope I don't have to explain what the X1 and X2 means? (just messing with you....)
So after all that the tint of the Warm White is very close to the Xenon -
but there is the same caveat - the camera does not show everything my eyes can see - to my eyes the Scorpion Xenon seems a more pale straw yellow with a hint of green - whereas the Quark AA-Warm has more pink in its beam.
How about more down to earth incandescent flashlights?
Vs. 2AA MiniMag (Krypton on alkaline)
again pretty close in color tint -
this time the camera may be seeing a bit closer to my eyes
more red in the beam of the Krypton MinMag -
and this time in comparison the Warm White LED seems more pale straw yellow and may be even a hint of green!
- remember my eyes are not absolute measuring instruments I see differences and contrasts in comparisons.
Note: I deliberately used Alkaline AA in the 2AA MiniMag because there may be a disadvantage if NiMH are used due to their inherent lower voltage levels - and incandescent are very voltage dependent on their output.
Note2: the levels seem about the same - the level 2 - Low rating on the Quark AA is about 4 lumens - and the 2AA MiniMag has been guessti-rated at about 5.6 lumens(?)
How about the classic(-ally) maligned
vs. Mag Solitaire 1AAA
Moonlight mode would have been way too low for a meaningful comparison and even the next level up 2 - Low seems too much - but here it is anyway......
