Vincent, thanks for this explanation, but I have a question about if their is buck-boost regulating circuits in the qmini 123 (regular). The output for the qmini 123 is noticableably brighter with a rcr123 (3.7v) compared to cr123 (3.0v). Does this mean the qmini 123 does not have buck-boost circuitry?
From your description it sounds like a regular boost circuit -
The Q-MiNi 123 specs actually says:
Battery: One CR123A (3V max) "
A regular boost (only) circuit is by-passed when the battery is above Vf -
so in effect the LED is on direct drive - thus gaining in extra brightness.
Note: the operative word
above Vf - so by definition the LED is over-driven with a voltage that is above Vf.
The lower levels, I believe, are still there because the MiNi and Preon series use high frequency PWM.
Even though there is plenty of anecdotal evidence the light obviously "works" on 3.7V Li-Ion Rechargeable, and there are plenty of people who are quite happy using that on other flashlights which only have boost circuits (always nice apparently "getting something for nothing") -
I still strongly suggest not using it - as it is out of spec,
or if you are willing to risk it doing it very sparingly
(remember do this at your own risk - and this flashlight would not be under warranty for this out of spec usage)
- as I have a Fenix L1D-Q5 that I used to use as one of my comparison flashlights with very occasional Li-Ion -
that has turned a distinct violet blue in tint -
so much so that I had to replace it for comparisons.
So perhaps Li-Ion may not cause sudden death -
but probably long term permanent injury?
