I am in for an eiger head in HAIII or SS.
pl. excuse brevity & possible typos - sent from a tiny device.
CRI is not hard to achieve at high color temperatures. There are 100% CRI definitions available for color temperatures as high as 40,000 Kelvins, which is the approximate color temperature of the evening sky facing away from the sunset. There may be 100% CRI definitions for even higher color temperatures, but as far as I know, above ~40,000K the changes are mostly in the ultraviolet spectrum so we can't really tell the difference with our eyes.CRI is not a direct measure of color rendering. It is a measure of how closely an LED gets to reproducing how well an incan renders color. The cooler you get, the harder CRI is to achieve. The best XPGs as high as 4300 are only 80 CRI. At 85, that drops to 3200K.
The QTC pills can be converted to non-QTC spacers fairly easily.I want to buy a high-CRI head in an aluminum El Capitan. May I buy it with a level-8 non-QTC aluminum body from RMSK? Or are these available only for the new, QTC bodies?
to do that you just need to take the QTC material out from the pill, reassemble the pill and put it all back (except the QTC material), it will work exactly as a non QTC body, just that the body is a little bit longer.
