Wanted to complete the converter module in copper today, but, alas, my copper bar was only 7/8" in diameter while I needed 1". Hey, no problem--just do it in AL instead.
The converter module houses both the driver and the LED and serves as a massive heatsink also. The overall length is 20mm, with 8mm devoted to the treads on each end to connect to the head and the battery tube, while the remaining 4mm are exposed between the two.
Here's how it looked after I had completed the threads on one end and was about to turn the area to be treaded on the other end:
And after threading both ends:
Next to be tackled were the grooves in the external 4mm section--these are quite narrow, only .5mm and 1mm deep:
Once those were done, I needed to bevel the edges to match the head and the battery tube. Despite how carefully one might plan, there always seems to be some discrepancy between the size you wanted to turn and the size you actually turned. Normally, these would not be noticable to the eye at all, but with this bevel meeting a flat surface, it was important to get them pretty closely matched:
Once the bevels were in place and the threading done, then it was time to bore out the space for the driver. The depth of this bore is only 5mm, so I usually don't bother to drill first and then bore, I just use my boring tool to achieve the depth as well as the diameter that I want:
And this is the final depth, with a diameter of 13.80mm:
Of course, most standard drivers are now .55", or 14mm, in diameter, so the final bore is to place a lip close to the 14mm diameter and 1.6mm deep, which is the thickness of the standard PCB board that Wayne and Mike Jordan use. Here is the lip, which I make to 13.96mm and then prefer to sand the converter down to fit tightly:
One of the last operations is parting off the second stub:
Then that end, where the LED sits, gets faced nice and smooth, and for today, at least, I'm done. Time to assemble everything and take the final pics:
And a close-up the converter module.
Man, the camera with flash, is harsh--shows all the flaws. :shakehead
Should look a bit better when sanded and polished.
