smarkum
Looks like were are ONLY about 1/4 of the way there . . . Please register your interest . . . and then go tell you friends... come all, we CAN do this!!!!!
How would you install in E-switch in a Haiku body Mohanjude?
Normally the Veleno E-switches screw into E-series tailcaps from the end near the body, but with the McClicky packs the McClickies screw in from the tail-end by gripping the McClicky switches via the 2 dimples. As far as I'm aware the Veleno E-switches do not have the dimples to grip on.
Yes you are right. No dimples. I used a pair pliers on the 'cone' are of the switch and screwed it in. I expected to be scratched but looking at the switch there was no marks. I guess titanium is really quite hard and will not be easily marked by using a jewellers or small long lose pliers. It fits in without a problem as there are no o rings along the body to grip and cause resitance. The o ring is dropped in the bottom of the switch similar to a mclicky
Wow! I'm impressed that no scratches were caused during that procedure.
All the same, I think it would be easier if there were a couple of neat dimples on the flat area of the switch on either side of the "cone" for the purpose of gripping with needle-nose or circlip pliers when the E-series trit-switch is specifically intended for replacing a McClicky switch in an integral one-piece body with inbuilt tail-switch (like the McGizmo clicky packs or maybe also for Mac's lights).
Would it be possible to provide this? If so, I would be interested in one or two.
I'm still unsure how you change modes since the switch is electronic and not physical in nature.
Sorry, to be more clear. I understand the modes with the standard clicky. I meant with the Trit switch.
The instructions I've given are for the trit-switch.
With the clicky you can use a momentary push to go to the next level instead of switching it physically on and then off.
With the trit-switch you have to press on, then press off as there is no momentary facility.
That is the difference between the two.
The lack of the momentary facility for the trit-switch means that its slower to change levels and for a very fast interface like a McGizmo UI where the levels have to be changed very quickly, this may not be feasible.
The electronic switches are also shorter than mcclickies so this should also include the spacer for the battery just as Steve Ku has done in his run of e-series switches.
I'd be interested in couple pending cost and that above issues are sorted out, e.g. Spacer, holes/notches for plier installation, etc.
The switches are exactly as per Steve ku and will include the spacer, o ring and silicon seal.
Okay. Have a haiku now, so interested. I understand the ui, but does it work properly with the slower e switch?
Would be interested in 2 of them if these also fit McGizmo switches, what i expect, right?
