Acebeam E70 battery warning
oeL
Bavaria, Germany
Hi E70 owners,
Does the low voltage warning work for you? For mine, the flashlight does not step down, it just shuts off. Tested with two different devices. Voltage is about 2.9 V then.
EDIT: It seems that the battery warning (step down from high to mid/low) does only work when you start the flashlight in turbo mode. It will dim to high, and with a nearly depleted battery further down to mid/low.
When you start the flashlight in high and not switch to turbo, the E70 will simply shut down when the battery reaches the limit.
