Brock
I don't think they plan on Compressing their 3200 CF @ 4500 PSI in three minutes . Since I am also a SCUBA diver I know about these pressures. It is just above what many dive shops keep their fill station tanks at. A dive shop down in Madison, WI uses a ballast tank out of an old submarine (60,000 CF I think). They have a small (I think 10hp) compressor that runs almost constantly to "charge" the ballast tank during the busy time. You can walk in and get 80 CF @ 3000 lbs. in under a minute. The compressor can't fill it that fast, but you get the idea. This also relieves some of the heat issue.
One catch is the tanks can get very warm or cold depending on filling or draining. I think that would be an issue if you filled this car that fast.
I have see a hole through a concrete brick wall made from an exploding SCUBA tank, pretty impressive, then again I have seen a much more violent explosions from just 1/4 gallon of gasoline, I can't imagine 10 or 15 gallons!
On a side note my father always tells the story about what would happen now if we were to introduce electricity, think about it. "OK guys I have this idea to run high voltage to all the homes in the US." Is this dangerous? "Yes, if you touch it, it will kill you." How can we make it safe? "Just put about 1/16" of plastic around the wires." The story goes on and on, you can see how this would happen. Gasoline is probably the most explosive material most people will ever come in contact with, yet we deal with it all the time without thinking about it. Just keep an open mind.
